Here is our quick installation guide for our dear customers. Enjoy your workouts and have fun!
Step 1: Unpack the Components
Start by unpacking the One Punch Boxing Machine. Make sure you have all the components, including:
- The boxing machine body
- Boxing gloves
- Power adapter
- Mobile phone holder
- Power extension cord
- 6.5ft / 2 meters velcro for mounting
Step 2: Choose a Location
Select a smooth wall for mounting the device. Ensure the wall space can accommodate the dimensions of the One Punch boxing machine.
Step 3: Wall Mount the Machine
Use the velcro provided to securely mount the One Punch boxing machine on the selected wall. Ensure it is level and at a comfortable height for your workouts.
Step 4: Connect the Power
Plug in the power adapter to the One Punch boxing machine and connect it to a power outlet using the extension cord if necessary.
Step 5: Set Up the Mobile Holder
Attach the mobile phone holder to the machine and secure your phone in it. This allows you to use the One Punch app or track your progress while using the machine.
Step 6: Test the Machine
Turn on the One Punch boxing machine and follow the on-screen instructions to ensure it is functioning properly.
FAQs
Can I install the One Punch boxing machine on any type of wall?
The One Punch Boxing Machine should be installed on a smooth, solid wall. Avoid installing on uneven surfaces or walls that cannot support the weight of the machine.
What should I do if the machine is not turning on after installation?
Ensure that the power adapter is properly connected and that the outlet is functioning. If the problem persists, contact customer support.
If you are interested on how to remove the machine from the wall you can check this post or this video we prepared for you
